josh@ROUTER:~$ sh conf
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name OUTSIDE-IN {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
description OpenVPN
destination {
address 192.168.10.13
port 1194
protocol udp
state {
established enable
new enable
related enable
rule 30 {
action accept
description Plex
destination {
address 192.168.10.16
port 32400
protocol tcp_udp
state {
established enable
new enable
related enable
rule 40 {
action accept
description "Ethan Plex"
destination {
address 192.168.10.4
port 32400
protocol tcp_udp
state {
established enable
new enable
related enable
name OUTSIDE-LOCAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
icmp {
type-name echo-request
protocol icmp
state {
new enable
rule 30 {
action drop
destination {
port 22
log enable
protocol tcp
state {
new enable
send-redirects enable
source-validation disable
syn-cookies enable
address dhcp
description ValleyWAN
duplex auto
firewall {
in {
name OUTSIDE-IN
local {
name OUTSIDE-LOCAL
hw-id d4:ae:52:a6:26:75
smp-affinity auto
speed auto
duplex auto
hw-id d4:ae:52:a6:26:76
smp-affinity auto
speed auto
vif 7 {
address 192.168.7.1/24
description TEST
vif 10 {
address 192.168.10.1/24
description Servers
vif 20 {
address 192.168.20.1/24
description Desktops
vif 30 {
address 192.168.30.1/24
description WiFi
vif 40 {
address 192.168.40.1/24
description "Smart Home"
vif 50 {
address 192.168.50.1/24
description Management
vif 60 {
address 192.168.60.1/24
description Surveillance
vif 70 {
address 192.168.70.1/24
description "Guest WiFi"
vif 80 {
address 192.168.80.1/24
description HTB
vif 110 {
address 192.168.110.1/24
description Smoqueed
ethernet eth2 {
address 192.168.90.1/30
description "Lab Environment"
duplex auto
hw-id d4:ae:52:a6:26:77
smp-affinity auto
speed auto
ethernet eth3 {
address dhcp
description RiseWAN
duplex auto
firewall {
in {
name OUTSIDE-IN
local {
name OUTSIDE-LOCAL
hw-id d4:ae:52:a6:26:78
smp-affinity auto
speed auto
loopback lo {
description Loopback
nat {
destination {
rule 20 {
description OpenVPN
destination {
address 158.140.34.8
port 1194
inbound-interface eth0
protocol udp
translation {
port 1194
rule 30 {
description Plex
destination {
port 32400
protocol tcp_udp
translation {
port 32400
rule 40 {
destination {
port 32500
protocol tcp_udp
translation {
port 32400
rule 7 {
description TEST
outbound-interface eth3
address 192.168.7.0/24
translation {
address masquerade
rule 10 {
outbound-interface eth0
address 192.168.10.0/24
translation {
address masquerade
rule 20 {
address 192.168.20.0/24
translation {
address masquerade
rule 30 {
address 192.168.30.0/24
translation {
address masquerade
rule 40 {
address 192.168.40.0/24
translation {
address masquerade
rule 50 {
address 192.168.50.0/24
translation {
address masquerade
rule 60 {
address 192.168.60.0/24
translation {
address masquerade
rule 70 {
address 192.168.70.0/24
translation {
address masquerade
rule 80 {
address 192.168.80.0/24
translation {
address masquerade
rule 110 {
address 192.168.110.0/24
translation {
address masquerade
protocols {
static {
route 10.1.1.0/24 {
next-hop 192.168.90.2 {
service {
dhcp-server {
disabled false
hostfile-update disable
shared-network-name Desktops {
authoritative disable
subnet 192.168.20.0/24 {
default-router 192.168.20.1
dns-server 192.168.10.7
dns-server 192.168.10.14
domain-name sharrer.us
lease 86400
start 192.168.20.11 {
stop 192.168.20.254
shared-network-name Guest_WiFi {
subnet 192.168.70.0/24 {
default-router 192.168.70.1
lease 86400
start 192.168.70.10 {
stop 192.168.70.254
shared-network-name HTB {
subnet 192.168.80.0/24 {
default-router 192.168.80.1
lease 86400
start 192.168.80.10 {
stop 192.168.80.20
shared-network-name Smart_Home {
subnet 192.168.40.0/24 {
default-router 192.168.40.1
lease 86400
start 192.168.40.10 {
stop 192.168.40.254
shared-network-name Surveillance {
subnet 192.168.60.0/24 {
default-router 192.168.60.1
lease 86400
start 192.168.60.10 {
stop 192.168.60.254
shared-network-name WiFi {
subnet 192.168.30.0/24 {
default-router 192.168.30.1
lease 86400
start 192.168.30.5 {
stop 192.168.30.254
dns {
forwarding {
cache-size 0
listen-on eth1.10
listen-on eth1.20
listen-on eth1.30
listen-on eth1.40
listen-on eth1.50
listen-on eth1.60
listen-on eth1.70
listen-on eth1.80
listen-on eth1.110
listen-on eth2
name-server 192.168.10.14
lldp {
interface eth1 {
interface eth1.10 {
interface eth1.20 {
interface eth2 {
mdns {
repeater {
interface eth1.20
interface eth1.30
interface eth1.40
ssh {
port 22
system {
config-management {
commit-revisions 100
console {
device ttyS0 {
speed 9600
host-name ROUTER
ip {
arp {
table-size 8192
ipv6 {
disable
login {
user josh {
authentication {
level admin
ntp {
server 0.pool.ntp.org {
server 1.pool.ntp.org {
server 2.pool.ntp.org {
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone US/Pacific
Above is the config Im using. The issue Im experiencing is that when I have interface 0 and 3 enabled at the same time I experience network issues such as packet loss, and connectivity issues. If I enable int eth0 and disable eth3, set all the source nat outbound-interface to the eth0, everything works. If I enable int eth3 and disable eth0, set all the source nat outbound-interface to the eth3, everything works. But It will not work with both enabled. Any suggestions?
