any idea how to debug this?
i execute the command reboot and the reboot hang here.
A force reset is the only way the reboot ![]()
vm is running under kvm with ubuntu 22.04 as host.
Hi!
Do you have a commit archive in your configuration?
Might be related ⚓ T4412 commit archive: reboot not working with sftp.
Did you enable HTTP API? There is a bug for async to configure vyos with http api.
it’s related something is wrong current configuration , in fact ,there would be a configuration doesn’t match with configuration Could you full configuration ?
I mean I have found the issue, but why is this happend?
here my cloudinit minimal setup
I have updated the thread you are refering to with info on how to solve if the last config-version lines are missing.
However that mostly only applies if you try to upload a backup configuration through scp or similar to your VyOS device.
If its a fresh install and you use cloud-init for it to pick up which IP-addresses and hostname etc to use (that is you dont upload a custom config.boot to the device) I then think there might be some bug or such in the cloud-init-script for VyOS.
For example that the cloud-init script should add the “magic lines” at bottom of the config.boot it creates (if they are not already there).
so I have remove my two lines with ntp commands and no errors appears by the first boot with cloudinit. But why are these commands are outdated and must migrated?
config.boot now has at the end of the file, the 3 lines that is needed.
but the vyos hang also.
I have configured the http api and tested my cloudinit config without using http api but it hangs also
The two lines you posted looks good to me with latest 1.4-rolling.
If you do the trick of appending a correct postfix to the config-file then the config itself must be valid otherwise it might crash.
Could you upload the whole config you got there?
show configuration commands | strip-private
