VyOS version: VyOS 1.4-rolling-202205250217
I setup a VyOS router and an ipsec tunnel between VyOS and my Firewall Palo Alto which works, the tunnel is up.
From my LAN I can ping the VyOS router but I cannot ping local clients.
I setup the routes on both side, VyOS and Palo.
It worked for weeks and now suddenly it doesn’t work anymore.
My VyOS config is as follows:
set interfaces ethernet eth0 address ‘dhcp’
set interfaces ethernet eth0 description ‘OUTSIDE’
set interfaces ethernet eth0 hw-id ‘xx:xx:xx:xx:xx:d4’
set interfaces ethernet eth1 address ‘xxx.xxx.0.1/24’
set interfaces ethernet eth1 description ‘INSIDE’
set interfaces loopback lo
set interfaces vti vti0 address ‘xxx.xxx.0.254/24’
set interfaces vti vti0 description ‘pa-tunnel-address’
set protocols static route xxx.xxx.0.0/0 interface eth0
set protocols static route xxx.xxx.0.0/16 interface vti0
set protocols static route xxx.xxx.0.0/20 interface vti0
set protocols static route xxx.xxx.3.0/24 interface vti0
set service ssh client-keepalive-interval ‘180’
set service ssh port ‘22’
set system host-name xxxxxx
set system login user xxxxxx authentication public-keys xxxx@xxx.xxx key xxxxxx
set system login user xxxxxx authentication public-keys xxxx@xxx.xxx type ssh-xxx
set system name-server ‘eth0’
set system ntp server xxxxx.tld
set system syslog global facility all level ‘notice’
set system time-zone ‘Europe/Zurich’
set vpn ipsec esp-group vyos-pa-esp compression ‘disable’
set vpn ipsec esp-group vyos-pa-esp lifetime ‘3600’
set vpn ipsec esp-group vyos-pa-esp mode ‘tunnel’
set vpn ipsec esp-group vyos-pa-esp pfs ‘dh-group14’
set vpn ipsec esp-group vyos-pa-esp proposal 1 encryption ‘aes256gcm128’
set vpn ipsec esp-group vyos-pa-esp proposal 1 hash ‘sha256’
set vpn ipsec ike-group vyos-pa-ike close-action ‘none’
set vpn ipsec ike-group vyos-pa-ike dead-peer-detection action ‘clear’
set vpn ipsec ike-group vyos-pa-ike dead-peer-detection interval ‘30’
set vpn ipsec ike-group vyos-pa-ike dead-peer-detection timeout ‘90’
set vpn ipsec ike-group vyos-pa-ike ikev2-reauth ‘no’
set vpn ipsec ike-group vyos-pa-ike key-exchange ‘ikev2’
set vpn ipsec ike-group vyos-pa-ike lifetime ‘86400’
set vpn ipsec ike-group vyos-pa-ike proposal 1 dh-group ‘14’
set vpn ipsec ike-group vyos-pa-ike proposal 1 encryption ‘aes256’
set vpn ipsec ike-group vyos-pa-ike proposal 1 hash ‘sha256’
set vpn ipsec interface ‘eth0’
set vpn ipsec log level ‘2’
set vpn ipsec log subsystem ‘any’
set vpn ipsec site-to-site peer xxxxx.tld authentication id ‘xxx.xxx.160.66’
set vpn ipsec site-to-site peer xxxxx.tld authentication mode ‘pre-shared-secret’
set vpn ipsec site-to-site peer xxxxx.tld authentication pre-shared-secret xxxxxx
set vpn ipsec site-to-site peer xxxxx.tld authentication remote-id ‘xxx.xxx.10.66’
set vpn ipsec site-to-site peer xxxxx.tld connection-type ‘initiate’
set vpn ipsec site-to-site peer xxxxx.tld default-esp-group ‘vyos-pa-esp’
set vpn ipsec site-to-site peer xxxxx.tld ike-group ‘vyos-pa-ike’
set vpn ipsec site-to-site peer xxxxx.tld ikev2-reauth ‘inherit’
set vpn ipsec site-to-site peer xxxxx.tld local-address ‘xxx.xxx.160.66’
set vpn ipsec site-to-site peer xxxxx.tld vti bind ‘vti0’
set vpn ipsec site-to-site peer xxxxx.tld vti esp-group ‘vyos-pa-esp’
vyos@vpn-endpoint:~$ show ip route
S>* 0.0.0.0/0 [1/0] is directly connected, eth0, weight 1, 00:01:56
S 0.0.0.0/0 [210/0] via 85.217.160.1, eth0, weight 1, 00:01:58
S>* x.x.0.0/16 [1/0] is directly connected, vti0, weight 1, 00:01:56
C * x.x.0.0/24 is directly connected, vti0, 00:01:59
C>* x.x.0.0/24 is directly connected, eth1, 00:02:00
S>* x.x.0.0/20 [1/0] is directly connected, vti0, weight 1, 00:01:56
C>* x.x.x.x/23 is directly connected, eth0, 00:01:59
S>* x.x.x.0/24 [1/0] is directly connected, vti0, weight 1, 00:01:56
Palo Alto side:
<entry name="Tunnel-Exoscale">
<auto-key>
<ike-gateway>
<entry name="IKE_Gateway-Exoscale"/>
</ike-gateway>
<ipsec-crypto-profile>IPSec_Crypto-Exoscale-Phase2</ipsec-crypto-profile>
<proxy-id>
<entry name="xxx">
<protocol>
<any/>
</protocol>
<local>x.x.x.0/24</local>
<remote>x.x.0.254</remote>
</entry>
<entry name="xxx">
<protocol>
<any/>
</protocol>
<local>x.x.0.0/20</local>
</entry>
<entry name="xxx">
<protocol>
<any/>
</protocol>
<local>x.x.0.0/16</local>
</entry>
<entry name="xxx">
<protocol>
<any/>
</protocol>
</entry>
<entry name="xxx">
<protocol>
<any/>
</protocol>
</entry>
</proxy-id>
</auto-key>
<tunnel-monitor>
<enable>no</enable>
</tunnel-monitor>
<tunnel-interface>tunnel.1</tunnel-interface>
<disabled>no</disabled>
</entry>
</ipsec>
Do you know what is wrong?
Thank you for your help,
So here is the last step you need to complete in order to get things work - bring back policy rules on your Palo that are containing the following:
